Newbie choppy tool paths from simple shapes
Results 1 to 5 of 5
Thread: choppy tool paths from simple shapes
    Aug 2010
    canada
    Default choppy tool paths from simple shapes
    im trying to machine a simple interior feature (pocket) using BobCAD V26 and every time i post my code it posts the paths as 1000's of short lines rather than circular interpolations...
    i cant figure out how to change this, please help!
    May 2013
    Default Re: choppy tool paths from simple shapes
    Maybe check this out -- may not be the problem but still good info.
    http://www.cnczone.com/forums/bobcad...-3d-steps.html
    Aug 2010
    canada
    that helped a lot but it is still less than perfect, oh well. thank you for the reply
    Registered MikeC8's Avatar
    Dec 2013
    What type of tool path are you using? And was the file your working with imported into bobcad? If so what program was used to create it? Its possible that the geometry is created with splines, or several small segments.
    Aug 2010
    canada
    just browsing and stumbled upon this again lol, i was using AutoCAD to produce the geometries and then importing them to BobCAD.
