From what you've asked it looks like you want to manually drill 6 holes on a drill press, but your question is rambling and not clear.
If you don't want codes for something which can drill the holes for you then one assumes you need to mark your zero on the stock, measure and mark out your work, punch the centres and drill the holes?
I can't see why you'd be using a CAM system for manually drilled holes unless you were using a machine that could wield a spot drill or mark the work!
- Nick
