Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 11-14-2006, 12:28 PM
markjb is on a distinguished road
pdf to bobcad
can you inport a pdf file to bobcad v20
Old 11-14-2006, 12:55 PM
The One is on a distinguished road
BobCAD does not support pdf as an import type. However, you may be able to import the pdf as an object that can be viewed on the CAD screen. (Edit => Insert Object) When using this method you will have to create the geometry over the image, because the object itself will not be actual geometry.
Regards
Old 11-14-2006, 01:27 PM
*Registered*
justme is on a distinguished road
you other option is to bring the PDF into something like Corel Draw or Cadkey and save as DXF
