| BobCad-Cam Discuss all BobCad software here. |
I am trying to engrave a poem into wood. Using a 90 degree V bit that seems to work good, but I have one problem. I want to use Blackadder ITC font. When I insert the text into BobCad V20 it appears just like I want it until I vectorize it. Using .001 accuracy, have also tried many other accuracy settings it outlines the text instead of giving me a single stick font like I need. The outline creates a double cut and an unreadable image once it is engraved. How can I get a single center line per letter -vs an outline? Thanks for your help |
| Not exactly what I was looking for. I have many stick fonts available, perhaps I used the wrong terminology. What I am trying to do is take on the characteristics of the Blackadder ITC font with a single pass of the router -vs- an outline cut? Any suggestions on how to do that? |
| becikeja, With BobCAD you are going to need more than just a single pass. This is because the BlackAdder font has varying width as well as rough edges. There are different ways to handle this, you could pocket the shape (but this does not accomodate the V tip cutter). Or you could offset the letters to the inside, but you may loose some of the detail. Here is a script that you can use to do a little bit of what you want. Just put the script into your Script Directory. 1. Vectorize the Text. 2. Select the Profiles so that the arrows point the direction you want your cutter to travel. 3. Click on Special and then Scripts 4. Select this script from the window and click Execute. 5. Input the required information that the dialogues request. 6. Once the Paths are generated you can use the 3D button to generate the program, make sure that you do not have the Auto Roughing turned on as it might cause a lot more work than necessary. Regards |
| My understanding is that NCPlots 'StickPlot' needs a tool paths for each letter of the alphabet for each font type. You may need to create your own set. Suggest to get the varied widths of the BlackAdder font letters, the depth of cut could change while using your V cutter. |
| Tried the above script, Tried to offset the text and even tried additional script style fonts. Can't seem to get what I am looking for. I keep getting an outline of the letter when I vectorize the text. This is causing the letters to be to wide. I need a script style font that does not create an outline when I vectorize the text. I appreciate the help above. To be specific, I need a single pass script style font that is readible at .5 inch scale when cut with a V cutter at 1/16" depth. Maybe it's possible that BobCad just can't do it, I don't know. I'll keep looking. In the meantime if anyone has any thoughts on the subject I would appreciate hearing them. Thanks, |
#10
This link is just one reason it is so hard to get. http://gallery.bcentral.com/GID51280...EW-HERMES.aspx |
