Need Help! CNC Driver - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: CNC Driver
  1. #21
    Jul 2012
    Default Re: CNC Driver
    need manual and setup files for3040c cnc router engraver New CNC Router ENGRAVER Milling Machine Engraving Drilling 4 Axis 3040C Desktop | eBay
    Bought it off craigs list new to this game help will be appreciated
  2. #22
    Feb 2013
    United Kingdom
    Your problem is communication between the PC/controller software and the hardware, as you are trying to get this working with Mach3 your best place for help is the Mach3 Forum -
    General Mach Discussion
    you are far more likely to find someone with relevant experience there than here.
    Should you be unable to find the required driver/plugin all is not lost as replacing the chinese hardware with something Mach3 compatible need not break the bank, is not horribly complex, and has already been done many times by others -
    https://www.google.co.uk/search?sour...9i57.12885j0j8
    Regards,
    Nick
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
  3. #23
    Dec 2013
    If you don't have Mach3, you can use LinuxCNC. The process to get a machine under control is actually quite simple.
    Do you have a breakout board for the parallel port?
  4. #24
    Jul 2012
    Quote Originally Posted by compsurge View Post
    Yes not sure of pin config one online I found was wrong I have mach3
  5. #25
    Dec 2013
    Don't worry about the online mapping just yet. Can you identify the breakout board by part number or attach an image of yours or a comparable part?
    Your parallel port pins just need to point to pins that are physically attached to each of the corresponding inputs or outputs. If you are able to read the pins on the breakout board, you can just work your connections one by one.
CNC Driver
CNC Driver
