Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
  #13   Ban this user!
Old 09-28-2006, 01:10 PM
tjones's Avatar
tjones is on a distinguished road
Surfaces (if they match close enough) can be stitched together into a single solid. Bobcad is very good at this type of CAD. Once the surfaces are stitched they behave as a single entity. For that you can alter the solid just as if it were never sepperated into faces.
Like a said, Bobcad is very good at this.
  #14   Ban this user!
Old 11-03-2006, 04:55 PM
erase42 is on a distinguished road
just thought i would play around with this. i didnt use any splines just normal geometry. why does it render like the program is confused tho?
Old 11-08-2006, 02:41 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Send this to BCC Support and they will look into it for you. Not sure why it looks like that but there are a few things to consider.
1) Your PC's Processor and Speed
2) Your Graphics Card Settings or available RAM
3) Your Monitor Resolution
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
  #16   Ban this user!
Old 11-08-2006, 04:08 PM
Its a 2 gig AMD with a meg of ram with a pretty decent video card. it usually renders fine but sometimes a small segment will be inside out sort of. with the glossy side in and the dull side out, that was the effect this was having with this part. the odd colors bits are actually just a different level of reflectiveness. im going to post the file here, see how it renders on your machine and post picture if you will. thanks
  #17   Ban this user!
Old 11-09-2006, 08:39 AM
The One is on a distinguished road
You have more than one surface for each feature represented. They are nearly identical but they have slight differences.
Look at figure 1a. Do you see the interior lines that curve?
Look at figure 1b. Those surfaces were removed and we are left with rectanglular segmenting on the surface. I did nothing other than remove the extra surfaces.
Now look at figure 2a. This is the render when only one set of surfaces is selected.
Regards
ID:	25370   Click image for larger version
ID:	25371   Click image for larger version
  #18   Ban this user!
Old 11-09-2006, 10:53 AM
hey thanks for messing with it, i actually figured that out a little later and had better success. i really have little use for actual 3d rendering in my line of work, but it is fun to play with for personal projects. if you have experience with bobcad, do you know why sometimes i can't snap to an existing point, even when i have points set as snap points. usually ill be trying to snap the center of a square to a point that was created as an arc center, it will try to snap to grid points or whatever is near, but not to the actual point no matter how i try. i guess i could start a thread, but its not that big a deal just wondering if youve seen that.
  #19   Ban this user!
Old 11-09-2006, 03:02 PM
Give me the steps you are going through.
Rectangles do not have a center snap location, so I am a little confused. But I may be able to provide some help.
Regards
