Hi, EnAndTropy.
To really be of any help, we'll need to have a look at your .bbcd file. In order to upload it, you'll need to zip it. (The forum only accepts certain file extensions). The easiest way to do that is to save the file in BobCAD, then go into Windows, right click on the .bbcd file, click <Send To>, then [Compressed (zipped) Folder. Once you've done that, fire up a browser, and come back here to the forum, and when you have the posting edit box open, click on [Go Advanced], which gives you lots more options than the basic edit box. From there, down below the edit window, click the <Upload Manager>, upload your zipped .bbcd file, and add it to your post.
With that file in hand, we can see exactly what you're seeing, along with all of the geometry, and someone will then be able to help you get things straightened out. Not sure what caused the error with your images before, but you can also upload images that way, and it should work.
Cheers!
Luke
