dashed lines will allow the tool path to come off
simple example,I will do in V25 as I do not know what you are using,One tool path with advanced rough and one with adaptive rough/both 2D pocket
do you always have to extend the open side of the pocket so the cutter will come completely off?
- Video V26 Open Pocket
- Need Help!- V26 Open Pocket problems
- Need Help!- Milling an open pocket
- open pocket
- Open Pocket
Jrmach,
How come in your examples the tool paths curve outward after they clear the edge of the part instead of going straight out. You don't have a fillet to follow around the edge so why in the world would it do that?
Your seeing the cutter comp being applied.?????I think
I think it's just a series of lead-ins. It makes a little more sense to me when you see it cut or watch the simulation.
Turn off system comp. for the finish pass and it straightens the path for the finish pass.
The roughing passes you don't have that option.
"do you always have to extend the open side of the pocket so the cutter will come completely off?"
No, but there are times where creating an offset of the part profile creates a better result,allowing the user to set how far off the part the tool starts. Looking at the "strip" of parts you are making, using a profile with side roughing may make more sense.
1) You will force the tool to start off the stock,
2) You can edit your lead in, so the tool rolls into the part ( better for the tool )
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
Thread Title "open pocket 2D milling"
One of my Favs from a few years ago.High Speed Pocketing V23
"do you always have to extend the open side of the pocket so the cutter will come completely off"
No you do not... By default the software will start off the part by the radius of the cutter +. At this time I am not sure of the default additional offset value, I know it's hard coded and I am not sure what we set it to. If you need more clearance you would need to offset the geometry yourself.
As you can see in this screen shot of your part, the yellow is the offset for half the cutter, the purple is the center line start point off the part.
I think the area you are concerned with is this spot:
In this example we have a 3 sided open shape, which can be problematic due to the "rolling" around the edge... Yes you may need to edit your wire fame to "adjust" the way the tool path is generated for a more appropriate result.
In your example you have the lead set to ramp in.
You notice there is no "ramp" in the tool path, The tool just plunges in... Why? Well an open pocket is designed to work from the outside in starting off the stock. The dotted line are representing the "edge" of the part or the "edge" of the stock where the tool can plunge to depth and work it's way in.
In your example you are cutting a strip of parts and the boundary you have setup would cause the tool to plunge in the material.
This is what I think your setup would look like.
A different way to use the open pocket would be to create a 2 sided open.
Al DePoalo
Al,are you replying to a particular question that is not on this thread?Did the OP provide a file that I am not seeing ?
You are right, the file is the wrong file.... It was sent to me by a customer and referenced a thread. This was not the thread. My bad.
Al DePoalo
