Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-23-2006, 07:29 PM
southernexplore is on a distinguished road
BobCAD/CAM V21 and Mach3 Postprocessor
I am trying to drill holes with the drill cycles and it will not generate a program. Is anyone else having this problem? It shows the tool path but it does not put the program up. I tried it with another PP and it worked fine.
Help!
Tommy C.
Old 07-23-2006, 07:42 PM
*Registered*
lakeside is on a distinguished road
cqn you post file
Old 07-23-2006, 08:01 PM
Here it is! This is the first time I have tried a cabinet door.
Tommy C.
Old 07-23-2006, 08:49 PM
*Registered*
unles you are running version 21 you need a point in the arc center attached you will see now you can select points and drill in cam side
here your code
N1G40
N2G80
N3G90
N4G54
N5 M6 T1
N6G81 X6.75 Y10.5 Z-,5 R.1 F5.0 G99
N7 Y2.5
N8 X8.75
N9 Y10.5
N10 X10.75 Y2.5
N11 Y10.5
N12 X12.75 Y2.5
N13 Y10.5
N14 X14.75 Y2.5
N15 Y10.5
N16 X16.75 Y2.5
N17 Y10.5
N18 X18.75 Y2.5
N19 Y10.5
N20 X20.75 Y2.5
N21 Y10.5
N22 X22.75 Y2.5
N23 Y10.5
N24G80
N25M30
Old 07-23-2006, 09:10 PM
*Registered*
Where you are using version 21 (as I see now) you can use the pick and match this will select all radius that are the same
Old 07-23-2006, 09:14 PM
Thanks Lakeside for the help.
I am running V21 and it does not work. Are you using the mach3 PP and I wonder if it is the same as the PP I am using?
I just tried with the points selected nd it still does not writethe code.
Tommy
Old 07-23-2006, 09:16 PM
*Registered*
Your software may not be set up right I just download the mach3 post and you see it worked try down loading and installing the post agian
Old 07-23-2006, 09:23 PM
Can you tell me how to do this?
Tommy
Old 07-23-2006, 09:26 PM
*Registered*
go to this site http://www.bobcad.com/index.php?sele...lic_html/posts
click on the post mach2,3 cleck run install ver.21
Old 07-23-2006, 09:29 PM
I got it to write the code but it is not putting in the depth or this info. Are you doing this yourself before hand?
N1G40
N2G80
N3G90
N4G54
N5 M6 T1
It is only putting this up:
N2G81 X6.75 Y2.5
N3 X8.75
N4 Y10.5
N5 X10.75 Y2.5
N6 Y10.5
N7 X12.75 Y2.5
N8 Y10.5
N9 X14.75 Y2.5
N10 Y10.5
N11 X16.75 Y2.5
N12 Y10.5
N13 X18.75 Y2.5
N14 Y10.5
N15 X20.75 Y2.5
N16 Y10.5
N17 X22.75 Y2.5
N18 Y10.5
N19 X6.75
N20G80
Tommy
Old 07-23-2006, 09:38 PM
*Registered*
you need to impit in second box see below make sure you use a (-) negative value
  #12   Ban this user!
Old 07-23-2006, 09:41 PM
I have it working now after downloading the new post. Are you canceling cutter comp and others yourself beforehand and then doing the drill cycle or is Bobcam generating the cancelations?
Tommy
