Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-17-2006, 08:05 AM
Kiwi is on a distinguished road
Geometry from NC 3D Setting
I've written a program to generate 3D Arc Helix GCode but unable to get this profile to show as 3D on the CAD side.
Worked great yesterday but I must have altered a setting.
When I now run 'Geometry from NC' I can only get a 2D profile.
Pics attached showing the difference.
Please advise if you know which setting I've altered.
Name:	2D Tool Path.jpg‎
ID:	19959   Click image for larger version
Name:	3D Tool Path.jpg‎
ID:	19960   Click image for larger version
Name:	Part of Code used.jpg‎
Old 07-18-2006, 01:13 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Wink
Check your 3D settings on the CAM side. It defaults back to 2D when BCC CAM Side is Closed then reopened. In the picture your 3D button is OFF.
What Version of BCC are you using? That is great what you have done. Sharp!!!
Now Check This Out!!! New V22!!!!!!!!!!!!!
http://management.cadalyst.com/cadma....jsp?id=357719
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 07-18-2006, 07:29 AM
Problem Solved
Solved my problem...It was my program. I had made a change which upset the maths.
tobyaxis.
It appears when 'Geometry from NC' the 3D button does not need to be ON for a 3D drawing to be drawn onto the CAD side. Thanks for your help.
V22 looks a much better format.
