Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 05-27-2006, 12:54 PM
bpmufx is on a distinguished road
Mach2 Post for Bobcad v19
Has anyone seen the Mach2 post processor for Bobcad V19 crash the app? I have other posts for other machines and have not had a problem. I've never actually crashed Bobcad until now, but I loaded the Mach2 post (from Bobcad site) and can't get the simplest of toolpaths to post out without crashing.
Does anyone have some thoughts on the matter?
Thanks in advance
Evan Brainard
Windmere Design
Autodesk Inventor Consultant
windmeredes@comcast.net
Old 05-29-2006, 10:47 PM
lilricky2 is on a distinguished road
All it did for me was crash and ruin metal. I use a couple of other post-processors instead. The Fanuc 6M simplified works pretty well. I am, however, new to cnc and someone can probably give you a better suggestion.
Rick
Old 05-29-2006, 11:13 PM
HuFlungDung's Avatar
Moderator
WAG: you might be missing a script (or some scripts) that the post requires to work, or such scripts may not be located in the correct folder.
When Bobcad crashes, it is a good idea to to clean out your temp folder to eliminate troublesome old remnants of the previous session from your computer.
Old 06-03-2006, 10:52 PM
Well after doing some tests I'm convinced that something is amiss with the Mach posts.
This is not a BobCAD application problem. I'll be in touch with their tech supt guys at the begining of week.
I too am having some success with Fanuc 6M simplified but not with out modifying the code a little. I've yet to find a post that works out of the can with MachX.
Evan Brainard
Windmere Design
Old 06-04-2006, 08:14 PM
Same here. I'd be very interested in their response. I mentioned it to a tech about a half hour before quittin' time on a Saturday and he told be he didn't have time to look at it.
Rick
Old 06-06-2006, 06:38 PM
OK, so I had a long talk with BobCAD's main Tech Supt guru. After showing him some screen caps he admitted that the Mach2 post was the culprit, and he proceeded to log onto my machine and revise the post on the spot! I have to say that when it comes to Tech Suport they are very good.
So now I have what seems to be a very stable post for Mach2. I asked him to make sure it was posted on their site and he assured me it was already done.
So, please check out the following site:
http://www.bobcad.com/index.php?sele...lic_html/posts
The Mach2 should be the revised one. Good luck!
Evan Brainard
Windmere Design
Old 06-06-2006, 08:33 PM
*Registered*
lakeside is on a distinguished road
Bobcad did the same for me on a post for a yasnak controller. Just downloaded the support tool and they took over. Bobcad support has been outsttanding the last three years I have been using there software. It too bad there sales force is the worst group of people to deal with
Old 06-06-2006, 09:04 PM
Thanks Evan, thats a better response than I received. I down loaded the post and I'll try it out tomorrow.
Rick
Old 06-07-2006, 02:18 AM
Hey Rick,
Post your results here cause if you find it isn't right, I'll call em back.
Evan Brainard
Windmere Design
Old 06-07-2006, 03:01 PM
O.K. I had to hand fit the part today, It'll probably be this evening or in thr morning before I start cutting now.
Rick
