05-14-2006, 02:00 PM
I’ve been playing with the scripting on a AHHA Tapping cycle and there are a couple things that I can’t get to work right first when you execute the script It does not number the last two lines then if you pick more then one point it will group those lines onto other lines, Second on my second ask header is there a way to have my list of tap sizes run vertical instead of horizontal because it cuts them of after #6 or is there a way to put them in window were you can scroll to select the one you wont ,and last one on the second ask header if you cancel out of it an error comes up saying FEED = SPEED / Tap error I put a if canc Then Exit command under the FEED = SPEED / Tap line but it cancels every thing when you select your tap size Is there another place to put that line so that way you don’t have the error if you push cancel but still generate the code . Any Ideas on what I did wrong or help on the script would be greatly appreciated Thanks |
