Results 1 to 4 of 4
Thread: Another noob with an elementary question.
    Apr 2006
    UK
    Red face Another noob with an elementary question.
    I'm just experimenting with bobcad, I've looked at the tutorials from Sorin. I went to have a go at my first part. (a upper arm for a model Monster truck)
    My question is this, I can create arcs but how do I change their orientation?
    To further explain, when I create an arc in the top view the circle appears as a circle as viewed from above, so I switch views to side view to create an arc, say like a wheel on a car ( to illustrate) but the arc is still created in the top down plane (just a line) not the side view plane.
    What am I doing wrong or not doing before or after?
    If further clarification is needed, just say so.
    I did try searching but as you can see from my explaination its a tricky question to verse correctly!
    Feb 2006
    try the BobCAD help file; look for "workplane".
    I'd be more specific but I'm not a bobcad user so have no clue beyond the terminology.
    Tiger
    Banned
    Mar 2006
    Boston
    select the arc and go to changes rotate x or y now your arc is in a differnce plane
    Apr 2006
    UK
    Talking Many Thanks
    Thanks very much, folks, I'll give it a try.
    Cheers D
