Originally Posted by
BurrMan
In BobCad, set your units to cm under the part peferences, then "Merge" the drawing into those dims. If you want BobCad to always be in cm, set that under the preferences default.
If your in the 3d toolpath "slice planar", there is a "lace angle" value set on the patterns tab. It's default is 90 degrees. 0 would rotate it how you describe.
I dont think V24 did much work with the stock yet. Your part can be anywhere you want it to be, like, above z zero. You have to set the "top of part" in the feature you are using though, to be above the top of the 3d model.
