To send a solid to Bobcad from ViaCAD, I'd use either a STEP (or STP) file or IGES file. STEP files don't really have any settings and they always import nicely to BobCAD, so I'd suggest you start there. If you want to try an IGES, I find the "Jama" version (option in the exporter) tends to be the most compatible with Bobcad. STEP files just tend to be very compatible all around, so would be my first recommendation. In ViaCAD, go to "File>>>Export..." which will bring up the export window settings. Then select "STEP" format and save the file. You can then either "Merge" the geometry into a new Bobcad file or open it directly with Bobcad. I prefer to use the "Merge" method, then I save the file as a .BBCD file once the geometry has been merged. Just a personal preference and either way will work. I do recommend saving it as a .BBCD file ASAP whether you merge the geometry in or open the geometry directly.
It's a bit late for me for checking files, but I'll try to remember to have a look tomorrow. It would be good if you post your .BBCD file so that we can see the toolpath that you've created as well. Just save it as a .BBCD, then create a ZIP file in order to post it here.
