Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-17-2006, 04:22 PM
orbimachine is on a distinguished road
Drill Cycle Codes do not show up in V19
I am having a problem converting from V17 to V19. I am using the same configuration file (is this the same as the post processor?) that I used for V17, but in V19 the drill cycles do not show up under the drop down menu. Where did they go. Also I have modified a configuration program to run on my Dynapath Delta 20ME controller. Is there a post processor out there already customized for this controller.
Old 03-17-2006, 05:34 PM
*Registered*
lakeside is on a distinguished road
Check on cad side under file, environment. General tab, scrip it should read C:\Program Files\BobCAD-CAM\BobCAD-CAM V19\Scripts
Below NC config file should read C:\Program Files\BobCAD-CAM\BobCAD-CAM V19\NC Config
If you don't this info click on tab next to scrip folder scroll down to program file folder scroll don to babcad scroll to scrip folder and click the folder will no open next go back to general page and hit the tab next to NC config. Repeat process to link with NC config folder for a bobad post go to support page and you will see a link to all of the post try this http://www.bobcad.com/index.php?select_page=posts_index&start=/home/bobadmin/public_html/posts/Dynapath(Delta)&parent=/home/bobadmin/public_html/posts
