Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-11-2006, 04:08 PM
DosHog's Avatar
DosHog is on a distinguished road
How do you get info???
When using the verify command, it gives several stats. I counted 33 for the drawing I am working on. How can I get a few of these into variables to use in my script? I did the following:
SelectAll
Verify
var_name1 = XMin
var_name2 = XMax
another_var_name = var_name2-var_name1
This does NOT work. I tried reversing the order (XMin = var_name1) That didn't work either.
The book doesn't mention it at all (big surprise). Does anybody have a clue?
Thanks in advance
Harvey
Old 03-11-2006, 06:46 PM
erase42 is on a distinguished road
the only way ive been able to solve problems even remotely similar to those is to find someone elses script and reverse engineer it. hopefully someone will come out of the wood work and help you with the proper syntax on that.
Old 03-12-2006, 12:16 AM
DosHog's Avatar
Thanks, I am hoping for something like that to happen
Old 03-13-2006, 08:14 AM
The One is on a distinguished road
Check check it out...
Verify Output, XMin = (your variable name), XMax = (your other variable name)
your thrid variable = your variable name - your other variable name
The key is the word Output. You need to place that word prior to the input windows you are trying to query in order for the value to be assigned.
Regards
