Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-18-2006, 11:10 PM
southernexplore is on a distinguished road
Post Processor For Mach3
I tried the Post that was on there web site and when the cam generates the program Mach3 really does some crazy things. (never cuts the right path)Anyone else have this problem and what can I do to fix it?
southernexplorer
Old 02-19-2006, 07:48 AM
ger21's Avatar
What exactly is it doing? Is it cutting large circles when it shouldn't, by chance?
Old 02-19-2006, 09:07 PM
Yes, there is circles in some wierd places.
_______
Tommy
Old 03-07-2006, 04:48 PM
phillby is on a distinguished road
Wrong way Circles
I had a similar problem importing a DXf file into 10Bulls CamBam. I fixed it by making a polyline and joining all the segments. My drawing had fillets on the corners, which had the rest of the circle as an indent instead of a fillet on one corner. It was bound up to the way circles are described and interpreted by the DXF maker and reader.
I am now ready to cut the piece.
I hope this helps
Brian
The Sawdust Creator
Old 03-07-2006, 09:13 PM
tjones's Avatar
tjones is on a distinguished road
This is an issue with the NC>driver setup. Change the settings in this and uncheck all the show only changed X and Y.
This should fix the problem. If not then let me know and I will check into it more.
Old 03-09-2006, 07:26 AM
The One is on a distinguished road
To be absolutely sure of the solution we need to know how your Mach3 software is setup. In Mach3 click on "Config" and then click "State...". What do you have selected for "Distance Mode" and "IJ Mode"?
You need to know what is in Mach3 before you can set the driver file in BobCAD correctly.
Regards
Old 03-09-2006, 08:20 AM
I have this problem fixed but I am having driver problems now. It was the setting for IJ mode, I just changed it to INC.
Tommy
Old 03-09-2006, 12:10 PM
tjones's Avatar
Good to hear it is working.
