Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-19-2006, 09:34 AM
Dave56 is on a distinguished road
Locking in settings
Hi All
We have just upgraded from V18 to V20, We are having a problem in the driver, we want to set the circular movement to half circle, and in the options for circular Motion, we want to set it to (R). When we come out and back into BobCad, these settings have changed.
Can anyone help.
Thanks Dave.
Old 01-19-2006, 11:20 AM
The One is on a distinguished road
You actually need to create a new post based on the one you have downloaded.
In the 'Insert NC Data Object in Drawing' dialogue type a name into the 'NC-Machine Setup' field. This should be a name that does NOT appear in the list box already. Then in the 'NC Machine Setup Based On' combo box, select the post that you have been trying to modify. Click OK. Then make the changes to the driver setup. When you close and reopen the program/nc-cam window it should hold the setting.
Regards
