I did get a manual for the 8025TG Dynamic. At this time I am reviewing the information.
Here is a sample drawing:
free image hosting
Here is a sample program for the drawing:
Code:
%00110
N000 G90 G95 S3000 T1.1 M4 M8(TURNING TOOL)
N010 G00 X.77
N020 G00 Z0
N030 G01 X-.01 F.003
N040 G00 X.52 Z.01
N050 G01 Z-.634 F.006
N060 G00 X.55 Z.010
N070 G00 X.41
N080 G01 Z-.092
N090 G00 X.43 Z.01
N100 G00 X0
N110 G01 Z0 F.003
N120 G01 X.18
N130 G03 X.3 Z-.06 R.06
N140 G01 Z-.095
N150 G01 X.39
N160 G01 Z-.14
N170 G01 X.5 Z-.3119
N180 G01 Z-.636
N190 G01 X.75
N200 G00 Z1.
N210 M01
N220 G90 G95 S1200 T2.2 M3 M8(.125 DRILL)
N230 G00 X0
N240 G00 Z.05
N250 G01 Z-.125 F.003
N260 G00 Z.1
N270 G00 Z-.115
N280 G01 Z-.250
N290 G00 Z.1
N300 G00 Z-.240
N310 G01 Z-.375
N320 G00 Z.1
N330 G00 Z1.
N340 M01
N350 G90 G95 S1000 T3.3 M3 M8(.05 WIDE GROOVE TOOL)
N360 G00 X.625
N370 G00 Z-.533
N380 G00 X.515
N390 G01 X.400 F.0015
N400 G00 X.515
N410 G00 X.75 Z1.0 M05 M09
N420 M30
Here is the coded commented out:
Code:
%00110
N000 G90 G95 S3000 T1.1 M4 Absolute IPR spindle 3000rpm Tool 1 direction counterclockwise
N010 G00 X.77 Rapid feed to X+.77 diameter
N020 G00 Z0 Rapid to face Z0
N030 G01 X-.01 F.003 Facing cut to X-.01 at .003 IPR
N040 G00 X.52 Z.01 Rapid to X+.52 Z+ .01
N050 G01 Z-.634 F.006 Feed to Z-.634 AT .006 IPR
N060 G00 X.55 Z.01 Rapid to X+.55 Z+.01
N070 G00 X.41 Rapid to X+.41
N080 G01 Z-.092 Feed to Z-.092
N090 G00 Z.01 Rapid to Z+.01
N100 G00 X0 Rapid to X0
N110 G01 Z0 F.003 Feed to Z0 AT .003 IPR, beginning of finish pass
N120 G01 X.180 Feed to X.18, start of radius
N130 G03 X.3 Z-.06 R.06 Generate a .06 radius
N140 G01 Z-.095 Feed to Z- .095
N150 G01 X.39 Feed to X+.39
N160 G01 Z-.14 Feed to Z-.14
N170 G01 X.500 Z- .3119 Feed along 10O taper
N180 G01 Z-.636 Feed to Z-.636
N190 G01 X.75 Feed off material to X+.75
N200 G00 Z1. Rapid to Z1., Safe position for next tool
N210 M01 Optional stop
N220 G90 G95 S1200 T2.2 M3 Start-up block for tool #2 .125 Drill 1200 rpm clockwise
N230 G0 X0 Rapid to X0
N240 Z.1 Rapid to Z.1
N250 G01 Z-.125 F.003 Feed to Z-.125 at .003 IPR
N260 G00 Z.1 Rapid out to Z+.1
N270 G00 Z-.115 Rapid into hole +.01 from last position
N280 G01 Z-.250 Feed to Z-.250 at .003 IPR
N290 G00 Z.1 Rapid out to Z+.1
N300 G00 Z-.240 Rapid into hole +.01 from last position
N310 G01 Z-.375 Feed to Z-.375 at .003 IPR
N320 G00 Z.1 Rapid out to Z+.1
N330 G00 Z1. Rapid to Z1., Safe position for next tool
N340 M01 Optional stop
N350 G90 G95 S1000 T3.3 M3 Start-up block for tool #3 Groove tool
N360 G00 X-. 625 Rapid to X-.625
N370 G00 Z-.533 Rapid to Z-.533, groove position
N380 G00 X-.515 Rapid to safe position above .5 turned diameter
N390 G01 X-.40 F.0015 Feed to X-.40 at .0015IPR
N400 G00 X-.515 Rapid out of groove to X-.515
N410 G00 X-.75 Z2.0 M05 M09 Rapid to safe Z position turn off spindle and coolant
N420 M30 End of program
The one issue tools cutting from the front side and back side of the part. Where BobCAD would only program from 1 side.... As far as the tool calls I do not see an index move for the tool position. Instead I see a tool number and offset.
Documentation:
T Tool number address
This a number between T1.1 and T32.32 that is used to specify the tool required.
The format for this number is T12.12 The 1st 2 digits are for the tool plate position of the tool.
This number indicates the location on the tool plate that the tool is at.
T12.12 The 2nd 2 digits are for the Geometry and wear offset to be applied to the tool selected.
In normal operation the 1st 2 digits are the same as the 2nd 2 digits T12.12
