Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: BobART Pro
  1. #13
    May 2008
    i thought from your drawing you wanted the bottom edge or flat area
    i got close , yours looks better
  2. #14
    Company Representative aldepoalo's Avatar
    Mar 2012
    There was a number of things I learned by making this part. Next step cut a sample and post the results... after that the fun part of sharing with everyone what I learned and the steps to making this part!
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  3. #15
    Registered BurrMan's Avatar
    Dec 2008
    That would be great.. I didnt do very well on it and you and dwood both had a great result...
  4. #16
    Mar 2012
    Burr,
    Don't feel bad, it's just one of those things ; ok where do I start. The good news is the test cut came out good, just a little more fine tuning and I have it just the way I want it
    I will detail ever step I took and why, what I did wrong and the adjustments I made along the way.
    Thanks for the support guys!
    Al
    Attached Thumbnails Attached Thumbnails BobART Pro-sample_2_rail.png   BobART Pro-sweep_sample_cut.png
    Al DePoalo
  • #17
    Mar 2012
    So I wanted to get started and talk about some of the steps I took to make this file. Attached is the update drawing which would be a good start.
    1) Even though the part I want to cut is a negative, I created the part as a positive, and inverted to make the negative.
    I found that in order to get the result I was looking for tying to model the part as a negative produce un wanted results that I could not get around. This may just be a training issue on my part, but once I started working the model as a positive things went along much smoother.
    2) I couldn't just emboss the outside shape and get the result I was looking for. So additional geometry had to be added to create the "cuts" in the model for the look I was going for.
    Attached Files Attached Files
    Al DePoalo
  • #18
    May 2008
    nice !!!!!!!!
  • #19
    Dec 2008
    Thanks Al. That helped alot!
  • Page 2 of 2 FirstFirst 12
    1. Need Help!- BobArt ?s.
      By Stampede in forum BobCad-Cam
      Last Post: 12-12-2008, 10:49 AM
    2. Anybody using BobArt?
      By shootingarts in forum Machine Created Art
      Last Post: 12-05-2007, 07:39 PM
    3. bobart
      By bobcadbrad in forum Product and Manufacturer Announcements
      Last Post: 11-01-2007, 05:07 PM
    4. v-22 Bobart is here!!
      By bobcadbrad in forum BobCad-Cam
      Last Post: 10-27-2007, 05:23 PM
    5. BobART 2D
      By CNCdude in forum BobCad-Cam
      Last Post: 07-27-2004, 10:06 AM
