I am using the MACH3 no ATC post with v24
How do I get the coolant to work? I set it in the individual tools but it doesn't come out in the post.
You can watch videos of how to edit a post processor with BobCAD. Or you can try using the attached post.
If you are running a machine that doesn't have a tool changer make sure to un check the ignore tool change option in your setup of mach 3.
This way every time mach sees a T1 M6 or what ever it will pause for you to "change a tool"
Al
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
