Results 1 to 3 of 3
Thread: Lettering and Ellipse Cutting for a Truss Rod Cover
    Apr 2011
    I am doing a job for a friend where I am making truss rod covers with his name and then cutting them out using an ellipse.
    All pretty easy I hear you say, and yes, very easy.
    Problem is getting the very fine router bits.
    Here are some pics:
    I got the very fine milling bits from here
    Garry
    Apr 2011
    Wood Lifted.....
    Even though I used strong double-sided tape, the wood cupped and lifted on each side.
    Will need to work out a reliable approach to mounting the wood as my clamps will get hit by the mill.
    I will make 'low' height clamps like I did for the archtop 2.
    I could probably do them one-at-a-time to remove chances of this happening.
    Garry
    Apr 2009
    Check into Mighty Mite Clamps.There are others also,look for something tthat uses Cam action to tighten.These clamps work by pushing on the side of material against a stop or an opposing clamp.
  1. Turn an ellipse?
    By hmc710 in forum Colchester Tornado lathes
    Last Post: 03-25-2011, 04:51 PM
  2. ELLIPSE
    By BOBINETTE in forum Mach Wizards, Macros, & Addons
    Last Post: 07-04-2009, 07:34 PM
  3. Newbie- Wrapped Ellipse
    By TZ250 in forum BobCad-Cam
    Last Post: 05-22-2009, 04:07 AM
  4. Need A Quote- CNC lettering on a MC cover....
    By IntrepidSE in forum Employment Opportunity
    Last Post: 04-09-2008, 06:29 AM
  5. Milling an Ellipse
    By Dave4x4 in forum General CAM Discussion
    Last Post: 02-28-2008, 04:24 PM
