Right clcik the features edit option and choose "post yes/no" to see an "x" for no, then re-post code and verify.
Hi Group,
Is there a way to only show certain feature in Verify and not all that I have created in the feature tree? I would rather not delete the feature just so it doesn't show up.
Thanks,
Pat
Hi SeanD,
Yeah, I tested it with the activex verify. I created a pocket and a profile on seperate geometry and excluded either op.. I think the internal verify needs code to go beyond 20 lines or so.. This was with V24.. Maybe test it on your system.. I'm willing to do more extensive tests if you need to get into it more
You are absolutely correct Burr.
