Here is a quick video where I "model" text on a bat.
You may want to do this if you need to actually 3d toolpath the text... If you have a 4th axis and just wanted to engrave, You could create the initial profile in the front UCS and extrude it staight up in Y as a flat surface, project your text onto that and just use 3d engrave while in cylindrical stock for 4th wrapping.
LinkBack URL
About LinkBacks
