Originally Posted by
bigspike
I am using V23 (build 1812) and I have the predator editor (version 2005.7.0.40 - which does not work, but that is for another post). I did learn that the verify predator built in to bobcad doesn't like manual tools.
I have watched all the training videos and either I missed it or it was not covered.
How do I program the tool paths to avoid any clamps that I will of course need to use?
When setting up my tools, I need to enter an overall tool length. Obviously the program needs to know where the end of the tool is in relation to the machine.
If I use Tormach tool holders, do I measure the length from the rear flange to the tip of the tool?
Is this the correct OAL to input?
What about drill bits?
Should I build a fixture or two to set the drill bits to protrude fixed amounts from the end of the chuck?
Then add the length of the chuck & Tormach chuck tool adapter?
In other words is the OAL the distance from the spindle to the tip of the tool?
I know this all seems so simple in theory but in practice ... I am just not finding this information.
