| BobCad-Cam Discuss all BobCad software here. |
I'll reply to my own question. I've got bobcad to talk to the DM2400: Create the objects and toolpath on the cad side. Start with no commands on the CAM side; pick the DM2200 (others probably work too) Use macro->program start to get a starting set of commands Use tool->cutting->auto to dump the toolpath in Dyna language Use macro->program end to get an END command (or just type it in) If you have G codes, you did something wrong. Send to the DM2400: Set up the DM2400 for download Line No. mode pick send/receive say yes/no until you get download, then the "Ready" prompt. 2400 N81 DSR/DTR I used a USB -> serial converter (laptop is USB only) to a serial cable 9 pin to 25 pin. I could download and run the program. Now I need to get drip code running. It involve adding a SKIP TO 900 with blank at 900, but I get the following problems: - the download won't complete unless the're an END command - the program self-check won't complete unless there's an END command - When running, the controller doesn't stop and accept more data from the laptop, it just loops around and trys to run again. Anyone have an example of Dyna code for the 2400 (or similar) that actually works? -Tom |
| Only 5 years later and I just got to this point physically. Then after hours and hours of late night reading and experimenting, I find this dead ended post. I wonder if you "Tomcat" ever got anywhere? A total of 3 posts. Either he did and everything has worked great since (I doubt it) or he gave up. I wonder if he got his machine to recognize arcs? |
I can supply a running mcam file |
