Results 1 to 3 of 3
Thread: Large Radius does not look correct
    Jun 2010
    So I have a part that is 7.5 in length and on one side has a 78 inch radius. I have created part just fine but when I created the radius it appears as a straight line. I'm sure there is some tolerance setting in Bobcad (V24) that can be adjusted so that the radius will visually looks correct??
    Attached is the drawing along with the toolpath (which visually looks correct). Notice the line is "straight".
    Any help would be appreciated.
    Thanks,
    Attached Files Attached Files
    Registered BurrMan's Avatar
    Dec 2008
    Preferences-Part (or Default)-Wireframe quality. Crank it to the right to see a very shallow curve.
    You will want to work at a lower value with larger, heavy models.. You can crank it up with more simple stuff, or if you have a beefy enough display adapter.
    Jun 2010
    Worked perfect thanks!
    I am here: http://tapatalk.com/map.php?fkd0ob
  1. Replies: 7
    Last Post: 10-05-2011, 11:43 PM
  2. Need Help!- Radius to end of Arc Differs From Radius to Startline
    By Bob La Londe in forum Machines running Mach Software
    Last Post: 08-09-2010, 10:16 PM
  3. Need Help!- Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 12:28 AM
  4. Cutting Large Radius with Endmill Tilted
    By MotoDan in forum General Metalwork Discussion
    Last Post: 10-22-2008, 12:38 PM
  5. large radius endmill
    By kentsui in forum Toolgrinding & Toolgrinding Machines
    Last Post: 07-09-2008, 07:30 AM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
