Results 1 to 3 of 3
Thread: making surface into solid
    Jan 2010
    I am trying to make a solid helix I was able to sweep a circle along a helix so I have a tube. How do I make it a solid or is there another way to go about this?
    Registered BurrMan's Avatar
    Dec 2008
    Using layers, to make it easier on yourself, extract the end of the tubes edges to a new layer, then run the planar command on them (The ends should be planar if you swept a circle). This will create 2 round endcaps. Use stitch surfaces to solid to make it a solid.
    Jan 2010
    I tried what you said and it looks like a solid but the software does not look at it that way. It will let me add it to something but if a subtract it, it only subtracts the surface. I found another way to do it I used half taruses at an angle and added them together to make my spiral. Thanks for your help.
  1. Need Help!- Bobcad v24 Surface to Solid
    By CADmantoo in forum BobCad-Cam
    Last Post: 06-17-2011, 10:33 AM
  2. Problem- What does stitch surface to solid do?
    By benjamint76 in forum BobCad-Cam
    Last Post: 01-29-2011, 03:32 PM
  3. Problem- STL TO SOLID OR SURFACE
    By grand master x in forum Mastercam
    Last Post: 03-26-2010, 03:45 PM
  4. from solid to surface
    By nabil_elbadri in forum Solidworks
    Last Post: 04-29-2009, 02:07 PM
  5. solid surface cnc choice
    By EvanB in forum Commercial CNC Wood Routers
    Last Post: 04-08-2007, 10:12 AM
