Results 1 to 5 of 5
Thread: AutoCAD 2D Milling CAM Recommendations
    Oct 2011
    CAM Software Recommendations
    CURRENT:
    1) Have a old benchtop mill/engraver that is near dead and never could cleanly import the AutoCAD files in.
    2) Orderered a Haas MiniMill to replace and expand our capabilites some (still 2D).
    3) NON-machine house (no CNC operators - our Tech guy and Engrs are support to the assemblers).
    4) Primarily this cell assembles custom light electro-mechanical assemblies where we mill low volume (5-10/day) plastic cases for switches, etc to be mounted into the case.
    5) AutoCAD 2007 files.
    RECOMMENDATIONS:
    - One local knowledgable rep. is advising SurfCAM 2D (he also carries FeatureCAM and DELCAM). My brother's large machining company uses MasterCAM. I have heard some use BobCAM as well.
    We need good same day support and easy to use software that works. Thanks!
    May 2004
    GibbsCam is one of the easiest to use, but hardest to learn. You did not mention you wanted cheap, so I won't go into those. MasterCam is also hard to learn, but has the best support, not because of MasterCam, but because of this web site.
    http://www.kirkcon.com/
    Registered The Engine Guy's Avatar
    Jun 2008
    UK
    Quote Originally Posted by BradS. View Post
    CURRENT:
    RECOMMENDATIONS:
    If memory serves me right you shouldn`t need any Cad-CAM software for simple 2D stuff if you have a HAAS machine, the control will have as standard a form of "conversational" programming they call "Visual Quick Code" that you can easily do at the machine so if I were you I would have another chat with whoever you are buying the HASS MiniMill from and find out exactly what it will do or simply wait for it to turn up and the engineer who sets-up/commissions the machine will be able to show you!!
    If I`m right then you may not need to spend on any Cad-CAM software for what you do !!!
    If I`m wrong then it is a "pay for" option
    Regards
    Rob
    Feb 2010
    I've looked at a lot of CAM software in the last year, and hands down, the easiest to use for me is VisualMill. It's really affordable as well.
    Registered BurrMan's Avatar
    Dec 2008
    Seems like a General question, but since you asked it in the BobCad forum, BobCad is plenty capable and doesnt cost anything near the other products just mentioned (Except for programming at the Haas controller) But BobCad would be far more capable than the Haas controller.
    1. Newbie- AutoCAD 2D Milling CAM Recommendations
      By BradS. in forum General CAM Discussion
      Last Post: 02-22-2012, 08:01 AM
    2. New Machine Build- Milling from AutoCAD LT
      By nelrodamus in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-06-2010, 10:17 AM
    3. Need Help!- Recommendations for clean HDPE milling
      By cnczoner in forum General Metal Working Machines
      Last Post: 10-03-2008, 11:00 PM
    4. Milling Brass 360, recommendations?
      By skyline in forum General Metalwork Discussion
      Last Post: 06-09-2008, 04:58 PM
    5. Need recommendations for milling titanium
      By jeremyinnys in forum General Metalwork Discussion
      Last Post: 09-21-2006, 06:15 AM
