Results 1 to 2 of 2
Thread: V23 goes behind solid
    Feb 2012
    I'm trying to cut three radi on rectangle. I can get it to work with "extents" option on but when I go to "part bottom" extents it cuts behind the radius. It will not stay on top of the part. I have gotten it to work if I include the top part of the rectangle but thats taken 5 hrs to cut just 2 passes. I would like to cut each individual radius on it own. If you flip the part over you will see that it cuts into the sides or sometimes it will do the back of the radius all the way to the bottom.
    Registered BurrMan's Avatar
    Dec 2008
    Hey Spitter,
    didnt get a file attachment to help explain your issue. Be sure to zip it with a right clcik-send to-compressed zip so it will upload here... Also, if it is larger that the forum allows, then you may need to use an external file upload and a link to present it here.
  1. Need Help!- solid into 2d
    By 1234567 in forum BobCad-Cam
    Last Post: 10-17-2012, 06:56 PM
  2. Art over a solid
    By wldngmstr in forum Mastercam
    Last Post: 02-10-2011, 03:32 AM
  3. Solid for CAS
    By garnetram in forum Okuma
    Last Post: 07-08-2009, 05:36 PM
  4. Solid To 2d
    By osomaker in forum Mastercam
    Last Post: 12-27-2006, 01:42 AM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum General CAM Discussion
    Last Post: 09-15-2004, 07:25 AM
