"current point same as end point of arc" Please help!
Hello I am using bobcad V23 and a desk cnc controller. I am trying to cut a circular pocket and keep getting the "current point same as end point of arc" message when I load the gcode in desk cnc. it gives this error code for line N07
I have tried usng a contour as well as just a circle drawn with coordinates from the menu. I keep getting the same error. It will cut other shapes fine just no circles. Anyone have any idea what the issue is? Thanks Chris
(; PROGRAM NUMBER)
(; PROGRAM NAME - .032 PKT 3.NC)
(; POST - DESKCNC MILL)
(; DATE - SUN. 02/12/2012)
(; TIME - 09:32PM)
N01 G90
(;JOB 1 POCKET)
(;FEATURE POCKET)
N02 S10000 M03
N03 G00 G90 X.001 Y0.
N04 M08
N05 Z.1
N06 G01 Z-.08 F24.
N07 G03 X.001 Y0. R.001 F40.
N08 G01 X.006
N09 G03 X.006 Y0. R.006
N10 G01 X.011
N11 G03 X.011 Y0. R.011
N12 G00 Z.1
N13 M05
(; END OF PROGRAM)
N14 M02
The problem is that it can not interpret the center with info provided. You either need to piece it as 2 arcs or use I and J data. I is on X axis and J on Y. They are incremental from the current point(start of that block).
Try changing these, assuming the arc cener is at x0y0....
Thanks guys. Bobcad got a new post processor for me today and it is now working. I do not know exactly what he did but he mentioned changing the arc's to incremential.
