Page 1 of 3 123 LastLast
Results 1 to 12 of 30
Thread: How can I switch off the automatic tools
    Feb 2012
    Germany
    Hi, I'am a german user of V24 and I would ask how can I switch off the automatic generated tools when I mill a new job. Each time BobCad generate a new tool in the tool list with a new toolnumber... that could be very dangerous if I don't delete the automatic generated tool..
    Ingo
    Feb 2012
    Germany
    Have no one here the same problem with automated generated tools? How can I swich them off?
    Dec 2005
    I can't get them off also.
    There is something I'm doing wrong.
    Later JeReMy
    Company Representative SeanDa's Avatar
    Dec 2011
    There is no way to have it default off. It will always default to system tool, which you can then toggle off the manual tool.
    Feb 2012
    Germany
    very dangerous (in V24)
    this is a very dangerous behavior! When every time, while generating a new milling feature, a default tool with default number is generated, you have to delete every time this default tool! Otherwise you generate a horrible machine crash if you have a full tool changer....It would make sense to swich off the automated tool generation and (!) tool numbering in the software preferences.
    I'am a German BobCad user since several years (V19,V21,V22,V23,V24) and tried to get an answer (and a solution!) for this problem. I never ever needed any support in that years and the only answer I got now from BobCad: Buy a support level!
    And then? Maybe I receive the answer: We can't change the situation...
    I'am a little bit confused
    Ingo
    Dec 2005
    nursum
    We just got support and had a list of things and this was number 1.
    The answer was it's a bug and can't be turned off. This is BobCad's
    answer.
    Also the in the chamfer tool/Parameter/Tool postion. The edge of part dim goes to center of tool not to edge of tool.
    On this forum is there a bug list?
    Later JeReMy
    Feb 2012
    Germany
    I expected that answer from BobCad! Maybe we should open a bug list thread.....
    I also had the problems with the chamfer path, but I thought it is a problem with the metric units because there are many bugs since several years refering to the metric/inch calculations in BobCad.
    Ingo
    Dec 2005
    Ingo
    Thanks for the tip "thought it is a problem with the metric units"
    I look out for that.
    I love to play with new software I was a network admin and
    play with Linux and Windows at home. And I "I'am a little bit confused" also with this software. I made my own post processor got everything setup.
    Then there's bugs, tricks and just poor programing everywere.
    Later JeReMy
    Dec 2011
    The chamfer issue has been submitted as the graphics show incorrectly. The item addressing System Tools, however, is not a bug. This is designed correctly in the software. There is a way to correct the issue with them writing into the file by attributing the Milling Technologies/Tools folder to be marked as read-only. Please remember if you do this, you will be unable to write tools to the file.
    Sean P Daugherty
    BobCAD-CAM Technical Support
    Dec 2005
    Sean
    "The chamfer issue has been submitted as the graphics show incorrectly."
    Sweet
    "The item addressing System Tools, however, is not a bug. This is designed correctly in the software. There is a way to correct the issue with them writing into the file by attributing the Milling Technologies/Tools folder to be marked as read-only. Please remember if you do this, you will be unable to write tools to the file."
    Sorry if this is not a bug then it's just stupid. The automatic tool?
    Why would anyone want it? I could be wrong, but then what good could come from this? I will try your solution.
    The is a bug list on the forum. Is there a "correctly in the software" list?
    Later
    Registered BurrMan's Avatar
    Dec 2008
    We dont use manual tools. Strictly system tools.
    Dec 2005
    "We dont use manual tools. Strictly system tools."
    The I can see the use System tools. But not Automatic tools.
    I want a database with the tools I use. I have that then system
    tools just get added in automaticly.
    Later JeReMy
  • Page 1 of 3 123 LastLast
    1. Automatic Alternating 120v Switch???
      By PriddyShiddy in forum Benchtop Machines
      Last Post: 01-10-2012, 02:59 PM
    2. Just IN- low cost machine with changing tools automatic
      By wyl6362708 in forum Videos
      Last Post: 11-23-2010, 07:19 AM
    3. Automatic Tools Changer at Reasonable Price
      By Mcyoda in forum DIY CNC Router Table Machines
      Last Post: 03-06-2009, 12:48 PM
    4. automatic touching off of tools and x/y alignment?
      By josh591 in forum CNCzone Club House
      Last Post: 07-13-2008, 12:52 AM
    5. Need Help!- Mazak QT15 with T32-B control does not switch to automatic mode
      By MarkusFunk in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 06-05-2008, 10:54 PM
