Results 1 to 6 of 6
Thread: Z Level Finish!
    Dec 2011
    united states
    Z Level Finish!
    i cant seem to get this toolpath correct as you can see it wants to cut though my part, i have tried some boundaries same results, i also tried changing the linking options, any help would be MUCH appreciated.
    Attached Files Attached Files
    Registered judleroy's Avatar
    Dec 2006
    Have you tried specifying a maximum z depth.
    Judleroy
    Dec 2011
    united states
    yes i have tried it both ways, it still wants to cut through the block, the only way it dose what i want is when i select the whole model, i dont see what the problem is, everything i try gives the same result
    Registered BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by kawman View Post
    Yes, this is your answer. If you select just a few "surfaces" of a solid object, then the feature no longer knows there is something there next to it, so it will just toolpath around the selected surface, without any concern for a surface which may be attached to it..
    You would control the toolpath with a "boundry". So, select all joined/adjoing surfaces which come into play of the cut area, then use a boundry to constrain the toolpath to the area you want..
    Here's a sample file where I attempted to constrain the toolpath, based on the surfaces you previously had selected... See if you can get the cut you want this way..
    Dec 2011
    united states
    yep that was exactly what i was thinking, i was trying to use the wireframe lines to create the boundary, Thanks again burrman,
    Dec 2008
    Hi Kaw,
    Yeah, for a boundry, the geometry needs to be planar. If you need to use the edges of your model to get a good boundry and they are non planar, you can create a plane surface, then project the 3d lines to it to flatten them out for a boundry selection.
    1. Problem with side finish (bottom finish is great)
      By tikka308 in forum Tormach Personal CNC Mill
      Last Post: 11-19-2010, 09:40 AM
    2. Need Help!- Z level finish Boundries
      By TGSTP in forum BobCad-Cam
      Last Post: 08-10-2010, 01:38 PM
    3. Z Level finishing minimum for finish
      By TPPJR in forum OneCNC
      Last Post: 02-16-2006, 12:01 AM
    4. Replies: 13
      Last Post: 01-10-2006, 09:22 AM
    5. Z Level Finish
      By Mortek in forum OneCNC
      Last Post: 02-05-2004, 12:02 AM
