Results 1 to 2 of 2
Thread: v23 full install
    Mar 2009
    v23 full install
    Where can i get a full download of v23 and predator? Im running windows 7 on a new laptop
    Registered The Engine Guy's Avatar
    Jun 2008
    UK
    Quote Originally Posted by 1234567 View Post
    Go here
    Untitled
    You will find V23 Build 1326 which is a good build, (Use the "V23 Build 1326 Full.exe" file) download and install it and also the 2 Predator files under the "Predator Installs" link, install them all and then go to the main BobCAD website and download and install the last build update which is 1812.
    Usually best to download the files to a folder on your computer and then install from there, you can get some "glitches" sometimes if the Internet is busy when you install direct from the website.
    On Windows 7 after installing I think you will need to set the software via the compatibility tab under properties to Admin permissions, think that`s what you need to do anyway
    Hope that helps
    Regards
    Rob
  1. New Install
    By kolias in forum Machines running Mach Software
    Last Post: 05-22-2009, 01:09 PM
  2. USB install
    By MrMazak in forum NCPlot G-Code editor / backplotter
    Last Post: 05-10-2009, 05:57 PM
  3. Install
    By jd@apm in forum General Electronics Discussion
    Last Post: 07-01-2008, 01:10 PM
  4. Install help
    By djmickyg in forum LinuxCNC (formerly EMC2)
    Last Post: 12-02-2007, 09:05 AM
  5. EMC Install
    By jhwatts in forum LinuxCNC (formerly EMC2)
    Last Post: 01-09-2006, 06:36 PM
