| BobCad-Cam Discuss all BobCad software here. |
#16
Even though I checked the clearance above the bridge when I attached the neck, I ended up with too much clearance. Given that I clamped the neck on, it must have increased the angle slightly. I have cut the neck off, saved the fretboard (overcut into the neck and barrel sanded) and truss rod (cut the neck up), and done a test neck after slightly adjusting my jig: ![]() I have also gone to the Benedetto laminated neck approach as I do not think that the method that I use for guitars such as Martin OMs is strong enough at the Archtop's dovetail, which is thinner and has less wood 'area' in the heel. I did a test neck out of rock maple to prove the laminated approach and to adjust my neck jig. I will probably use it sometime, as it is very nice (but plain) wood. Now waiting on some new neck wood. Garry |
#17
Still waiting on wood for new neck, so did some upgrades on my equipment. Redid the base of my router and inserted T channels into melamine. Problem is that I do not have much clearance for the vacuum fixture if I am going to get all the depth etc I need for the surface profiling. My solution is to make my own clamps out of 2" square tube. Still a bit of adjustment to do, but it will work... ![]() Garry |
#22
I leave the neck extension slightly high and use a jointer to plane it level with the rest of the neck. I will do this tomorrow as I want glue to be as strong as possible. I then need to make the neck extension match the top plate's shape. You can also see why I leave the heel oversize (ie wide). Any chips caused by the hand planing of the end grain (I used a Veritas Medium Shoulder Plane) will be removed: ![]() Garry |
#23
Pic of my new clamping arrangement on the CNC: ![]() I used to use a 'safety planer' attached to a drill press, but this is so much better! You hopefully can see the 1/8" shim that gives the head its taper. I also machined the back of the neck level, using the same approach with the shim etc. Then I manually shaped the neck. You can see my two small templates that I use to get the shape at the 1st and 12th frets with a rasp. Then I use a spokeshave to join the two 'curves': ![]() Glued the fretboard and headplate on so I can finish all the shaping and blending of the curves: ![]() Garry |
#24
Very disheartened as my router dropped its height adjustment (I have found that it is broken) when I was routing around the fretboard. Result is I am starting my THIRD neck for this archtop. |
| More Archtop goodness! | CyborgCNC | Musical Instrument Design & Construction | 1 | 10-25-2011 11:41 PM |
| Archtop Tutorials in Solidworks | CyborgCNC | Musical Instrument Design & Construction | 3 | 10-21-2011 09:44 PM |
| wanted:IGES LP archTop | In_Control001 | Musical Instrument Design & Construction | 1 | 06-26-2011 03:18 PM |
| To build an archtop guitar...? | Dookychase | Musical Instrument Design & Construction | 11 | 12-30-2006 06:18 PM |
| archtop guitar | Pookie | Musical Instrument Design & Construction | 6 | 12-20-2003 08:17 PM |
