Results 1 to 5 of 5
Thread: BobCad Nesting vs Me
    Nov 2011
    yes
    I played with nesting in bobcad it is new program for me. Strange thing I cannot find option to put one part inside another to save space. I used 1 degree rotation. It took minimum 5 min to put it together for my amd 1090 X6 and almost same time to me, maybe less.
    Here is picture of it.
    If you know how to improve it let me know.
    Attached Thumbnails Attached Thumbnails BobCad Nesting vs Me-bobcad_nesting.jpg
    Company Representative SeanDa's Avatar
    Dec 2011
    Part
    Try placing the part in the other. Then select it as if it is one part.
    Nov 2011
    Don't you think it calls nesting? program should do that.
    Dec 2011
    You can assign the parts that you want inside other parts to PIP from primary which will nest those parts in another part if there is available space.
    Nov 2011
    Thanks for reply. I googled bobcad PIP and found lesson
    http://www.bobcad.com/wp-content/med...art_Lesson.pdf
    I had 2 big parts and few small.
    I put small as PIP, big left as primary with priority 1 for both big parts.
    here is result. Small parts on top of big.
    Playing around I got better result with changing priority of big parts.
    But still results is useless. I have to tell program what parts TRY to put inside. If I will put PIP on part that at the end will not fit into any part it will NOT display on sheet at all. That means I have to check if I have all parts at the and on list.
    Most important!!!
    I fit these parts on 1 list easily, bobcad cannot with 0 margins.
    Attached Thumbnails Attached Thumbnails BobCad Nesting vs Me-1.jpg   BobCad Nesting vs Me-2.jpg   BobCad Nesting vs Me-3.jpg   BobCad Nesting vs Me-4.jpg
    1. X3 nesting
      By foxsquirrel in forum Mastercam
      Last Post: 08-11-2008, 11:03 PM
    2. Nesting...
      By WilliamD in forum Mastercam
      Last Post: 11-07-2006, 05:56 PM
    3. 2D On-Line nesting - Nesting on-demand !
      By mijo in forum Product and Manufacturer Announcements
      Last Post: 03-21-2006, 10:42 AM
    4. 3d Nesting
      By broncosis in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-24-2005, 09:38 PM
