Nothing special required. If you run into this, you could try load the STL into MeshLab and then save as STL, then load it into BobCad.
I tried loading several differnt stl files into BObcad 23 without success. They load ok in Meshcam and Cut3d. Does bobcad require something special in stl files?
Dan
