Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 10-15-2005, 12:18 PM
roni21702 is on a distinguished road
Question Using bobcad with Boss control
Does anyone know how to make the post put out a G75 before a G02-03. My boss control needs to see this before cutting a circle. If anyone has any ideas please let me know. Thank you for your help.
A Thayer
Old 10-27-2005, 08:04 AM
tjones's Avatar
tjones is on a distinguished road
If you always need this then it is simple. Go to the NC window under the setup>conversion window.
In the 'Original' window put G02 in the 'Convert to' window put G75G02
Do the same for G03.
Old 10-27-2005, 10:37 PM
This will put the two codes on the same line I think. Do you have any other thoughts.
Old 10-28-2005, 07:02 AM
tjones's Avatar
Only 2 things I can think of.
1) write a script to add these
2) get post specific for this type output (free if you have the support option)
or if there is one already in the posts (you should ask in the BobCad.com forum where someone might know or ask chris)
This would be so easy if BobCad gave us a line feed output in the convert.
Old 11-07-2005, 10:40 PM
MrHorsepower is on a distinguished road
Why not just generate the code then go in and add the G75?
