If the code is pretty standard.. (Haas , fanuc, Mach) the code should already give you a run time. If not then you may need some customizations. Take a look at this info it may clarify some of the editor setup for up..
Setting up the tool changes in the predator editor
BobCADV23 Predator Editor template changes. MCode Change
LinkBack URL
About LinkBacks
. I can read g-code pretty well though. Is there something else that could help me figure run times? The predator is very very confusing to me. For starters i cant figure out how to create the RVP file needed to run it! Thanks in advance. - Brett
