Results 1 to 8 of 8
Thread: Cannot select line by cursor hover
    Jan 2007
    United States of America
    Anyone know why BoobCAD V23 won't select geometry by cursor hover sometimes? ...yup, the cursor select is activated on the tool bar.
    Had no problems until I saved the file. After saving the only way to select geometry is to window pick! WTF???? Very frustrating!
    Rebooting doesn't solve it. I can open another file and I'm able to hover select. I've looked through preferences and find nothing. Besides, why would you want to disable that selection method?
    Some are destined to achieve greatness. Some are destined for failure and disappointment. While others have failure and disappointment thrust upon them. - WayneC
    Feb 2009
    if you have a contour selected it will not show you a selection.
    Jan 2007
    Quote Originally Posted by ssoptical View Post
    There are no contours defined, let alone selected.
    Company Representative
    Oct 2006
    Probably a graphics issue, Call support we can help.
    Jan 2007
    Quote Originally Posted by Sowen View Post
    The problem is FILE specific. NO OTHER BobCAD FILES EXHIBIT THIS ISSUE. I opened the problematic file with Auto CAD and did nothing but save it in Auto CAD. Closed the file and re-opened with BobCAD. No more problem. So what is it in the file structure that causes this problem???
    Sep 2010
    I have the same issue as of 2 days ago after updating W-7.
    Feb 2009
    I've had this trouble with ver 23. It seemed to me it was related to using blank function. Sometimes I could get it to select to work again if I would use the undo. After re-opening the file you lose the undo so I would delete some of the last things I did to get the select to start working again. My solution could have bee a coincidence.
    I have Win XP
    David L. Aery
    www.hooksolutions.com
    Oct 2011
    spain
    Mine was WinXP,I just want to upgrade it ,any good tips?
    Everyday is a beautiful day.[IMG]http://www.cuinsurance.org/xiao3.jpg[/IMG]
    1. X3 cursor problem
      By pilsnerglass in forum Mastercam
      Last Post: 09-12-2009, 06:21 PM
    2. Start plot at cursor
      By rsm169 in forum NCPlot G-Code editor / backplotter
      Last Post: 05-24-2008, 11:25 AM
    3. Problem- V9 Cursor Color Help
      By Joe Rodney in forum Mastercam
      Last Post: 05-21-2008, 10:20 AM
    4. cursor ghosting problem
      By Derdle in forum Surfcam
      Last Post: 05-21-2008, 12:10 AM
    5. No XYZ cursor key control on Mach2
      By alnicov in forum Mach Software (ArtSoft software)
      Last Post: 03-07-2006, 12:16 PM
