Page 1 of 4 1234 LastLast
Results 1 to 12 of 48
Thread: V23 - Pocketing off the part: Easier way???
    Jan 2007
    United States of America
    Hello all,
    I've searched exhaustively and cannot find the answer to my question. If already answered I would greatly appreciate a link.
    I'm finding nearly all the parts I'm running of late require basically a slot from the center to the edge, or all the way across. I'm using the standard pocketing feature and have the "high speed" pocketing feature installed. I choose to use the standard pocketing feature as this results in much shorter code for most parts. The problem I run into is BobCAD won't run the cutter off the part using the standard pocketing feature as it won't violate the solid line with the cutter during toolpath computation. Nor does standard pocketing recognize a broken line and treat it the same as HS pocketing does.
    Let's say for instance I want a .250" slot milled from one end of the part to the other along it's entire length using a .250" end mill. HS pocketing complains the cutter diameter is too big. And standard pocketing won't do it for fear of crossing the solid line. So as a work around I draw the part longer (or wider) than actual by at least the cutter diameter so standard pocketing will run off the part.
    My question is: Is there an easier way than having to continually out smart BobCAD? When the level of detail increases the time spent figuring out work arounds seems to grow exponentially.
    Some are destined to achieve greatness. Some are destined for failure and disappointment. While others have failure and disappointment thrust upon them. - WayneC
    Nov 2010
    new zealand
    As far as pocketing off the part extending the geometry is the only way with the standard pocketing tool path I think a lot of CAM programs are like this. The dashed line with High Speed pocketing is a great feature but I agree a serious amount of code is generated.
    For your slot I would create a center line in the position for the slot and run it of the job by the tool diameter on each side. Then I would turn that line into a Contour with the direction arrows running in the direction you want to slot.
    Then use the profiling tool path in 2D milling with no offset for the slot.
    I do a lot of milling that can be best described as facing with islands and normally use HS pocketing with all its code, but have just started looking at the side roughing feature in V24 as another way.
    Jul 2009
    One thought for your "slot"
    If you extracted one side and turned that into a contour, then used a profile feature. You could use the paralell lead and specify the cutter radius plus a bit. No "cutter is too big" crap there. LOL
    Jan 2007
    Thanks winaa and A1CNC for your relplies. I will ponder your line of thinking and give each idea a shot and evaluate the results.
    Feb 2011
    does your part require a slot outside the solid line??? if not, you could just plunge into hte pocket area and pocket out from there.... just a thought.
    Jan 2007
    Quote Originally Posted by zstangkrewson View Post
    Yes it does. And there are multiple slots/grooves intersecting the slot which run off the part as well in a perpendicular fashion. (To be clear when I say run off the part I mean the full width and depth of the slot/groove is open at the edge of the part when finished - no snipe/burrs.) The intersecting slots are 1/8" wide. 30 on each side of the 1/4" slot. Similar to branches on a tree.
    Mind you this is merely one example of many, but they all share the same commonality: simple slotting that must go to the edge of the part.
    Hand coding can get the job done, but I was hoping to get more of my money's worth out of BobCAD by applying it to the parts with 60 - 90 slots in order to save time.
    Thanks for your response and help zstangkrewson!
    May 2008
    are you working from a solid model or wire frame geometry????
    Jan 2007
    Quote Originally Posted by dwood View Post
    Wire frame
    Jan 2007
    I realize this is a bit late for a follow up, but things happen. I figure those who found themselves reading this thread may appreciate an answer/ending.
    A1CNC - I think you had the correct approach. Using the parallel lead has solved the problem of slotting to the edge when only having to cut one slot. In the application that prompted me to begin this thread I was attempting to select all of the geometry that had to be machined away (the tree branch thing). BoobCAD would create tool path off the part with the starting cut, not violate the 'boundary' on the slots between the beginning and end, then run off the part on the last feature.
    So, I wound up using Winna's idea and created a centerline down each slot (60 altogether), created individual contours, used no CRC, and selected parallel lead in with 0.050" + cutter radius keyed in, then vertical lead out at the end of the slot. Took a fair amount of time and I believe I could've hand coded it in the same amount of time - which is a disappointment. I'm really dissatisfied with BobCAD.
    Apr 2009
    HSP you can usually feed 2X of what normal pocketing.Something to keep in mind in other situations if you are worried about length of code.
    Jan 2007
    JrMach - I appreciate your input and help.
    The ONLY concern I have regarding the length of G-code the post processor generates is troubleshooting. Not only in HSP but with spiral cutter entry there's an excessive amount of code generated. Just yesterday I had a 125 piece order where I wanted to minimize tool changes in order to reduce cycle time. So, I decided to use a 6mm end mill to spiral into 1/4" plate and then open up the hole to a 10mm ID. Needed this in four places. There were nearly 2100 lines/blocks of G-code generated for those four holes alone. I'm pretty sure that could be cut down to less than 50 or so lines/blocks. Even fewer using subroutines.
    With 2100 blocks there's over 500 segmented arc moves per hole. Should there be a problem with a misplaced decimal or errant digit that's a boat load of single stepping on a simulator (not to mention at the machine) to find the problem. And, staring at a display looking at all the minute moves will drive a man to drink - excessively.
    Apr 2009
    there must be something in your post that needs attention.I get 561 lines of code total for something similar that you were talking about using pocketing tool path.With HSP I get 149 lines of code.There a few guys on here that know post processors real good.I am not one.That was with 4 spirals to bottom.Thats all I got sorry.
  • Page 1 of 4 1234 LastLast
    1. Problem- Part Zeroing - Anybody have a easier method than this
      By MMTechi in forum Haas Mills
      Last Post: 04-29-2010, 08:55 PM
    2. There has GOT to be an easier way!?
      By HackMax in forum Benchtop Machines
      Last Post: 08-28-2009, 11:39 AM
    3. New Machine Build- New easier CNC sulotion
      By roctech in forum Commercial CNC Wood Routers
      Last Post: 06-28-2009, 11:42 PM
    4. Which is better, easier?
      By dpmulvan in forum DIY CNC Router Table Machines
      Last Post: 10-31-2007, 12:55 PM
    5. please make it easier
      By Gandalf in forum Suggestions for the CNCzone.com site.
      Last Post: 02-18-2006, 06:49 PM
