Results 1 to 8 of 8
Thread: Creating Gears
    Feb 2011
    Question Creating Gears
    ive been using V23 for almost a year now, i have gotten very profiicient at holes patterns and cutting gears blansk without teeth, now ive been tasked to create a gear for a plating barrel, and it seems that no matter what i do, I cannot copy a 52 tooth gear that is 17.08" OD, at 3 pitch... I have googled for tutorials on how to create gears, but i ant find anything, maybe im searching the wrong subject, does anyone have any formulas that are simple to create gears of any size, pitch and tooth count?
    May 2008
    maybe this will help get you started
    pitch is actually pitch diameter
    you can see what i have set to get a gear
    17.080 dia.
    pitch dia. 16.50
    root dia. 16.25
    since i do not have the gear to measure the pitch and root dia are just a random number
    machinery's handbook may have some formulas to help out
    Nov 2010
    new zealand
    First you need to do some calcs
    From the info you have given I think your pitch may be wrong- pitch=number teeth+2/OD
    that equals 3.16167
    from here we can work out the pitch diameter=number teeth/pitch
    That equals 16.447
    now we need to work out the whole depth of the tooth=2.25/pitch
    That equals 0.7116 double this and take away from the OD to find the Root diameter
    .7116*2=1.4233
    17.08-1.4233
    that equals 15.6567
    plug these number in the gear generation utility under the Other Tab in BobCAD and you should get your gear.
    Takes me back to my apprenticeship days
    Jul 2003
    New Zealand
    Quote Originally Posted by dwood View Post
    ... 17.080 dia.
    pitch dia. 16.50
    root dia. 16.25....
    0.58 between OD and PD and 0.25 between PD and RD doesn't look right.
    My guess your gear with 52 teeth is 8 module (3.175 DP) which is 17.0079 OD, 15.5621 RD with 16.378 PD.
    Feb 2011
    it is 8 module!!! holy crap, i didnt know what 8 module was... nobody i work with did either, is there a chart i can use to figure out module vs pitch or = pitch???
    Ha Ha! im a newb, just a 34 year old who is doing what he can to keep a job... i have learned alot in the last year... and im hoping to learn more, im not real good at math, so i would join the training courses but my biggest fear is id fail them cuz of the math...
    Thankyou very much for the help, hopefully i can get something drawn today... PEACE!
    Feb 2009
    Quote Originally Posted by zstangkrewson View Post
    it is 8 module!!! holy crap, i didnt know what 8 module was... nobody i work with did either, is there a chart i can use to figure out module vs pitch or = pitch???!
    Gear - Wikipedia, the free encyclopedia
    The module system
    Countries which have adopted the metric system generally use the module system. As a result, the term module is usually understood to mean the pitch diameter in millimeters divided by the number of teeth. When the module is based upon inch measurements, it is known as the English module to avoid confusion with the metric module. Module is a direct dimension, whereas diametral pitch is an inverse dimension (like "threads per inch"). Thus, if the pitch diameter of a gear is 40 mm and the number of teeth 20, the module is 2, which means that there are 2 mm of pitch diameter for each tooth.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Nov 2010
    new zealand
    Is there a chart i can use to figure out module vs pitch or = pitch???
    Diametral pitch=25.4/module
    =25.4/8
    =3.175
    Feb 2011
    wanted to say thankyou to you guys and especially DWOOD for opening my eyes, v23 only has PITCH to enter instead of PITCH DIAMETER... once i realized that, making gear was easy! also thankyou for the formulas... helped alot, tyvm.
    1. Gears anyone?
      By 2Bits in forum Dolphin CADCAM
      Last Post: 08-09-2009, 05:51 AM
    2. Gears
      By georgecort in forum General Metalwork Discussion
      Last Post: 04-27-2007, 12:58 PM
    3. gears
      By georgecort in forum GibbsCAM
      Last Post: 04-21-2007, 07:11 AM
    4. who's going to GEARS
      By CerveloRod in forum CNCzone Club House
      Last Post: 09-20-2005, 08:11 PM
