Hi is this problem with all Z movements (ie drilling, pocketing) or with ramping moves only like the new contour ramping?
If it is only with contour ramping the problem will be with lines 64, 65, 66 I had the same problem with a V23 post I was trying to use.
I can post the lines if you need them.
Sorry miss read your posts it's feed rates your missing I'm not that skilled with posts so hopefully someone with more experience can help
LinkBack URL
About LinkBacks
