Results 1 to 12 of 12
Thread: machining times
    Nov 2010
    new zealand
    machining times
    Is there any way to find out or calculate machining time other than purchasing predator? with BobCad
    I know in masterCam you can find out total machining time without doing a verify by clicking info box.
    Sep 2011
    United States of America
    Atm there is no other way to compute tooltime other then with Predator Editor
    Registered judleroy's Avatar
    Dec 2006
    I don't know what version of bobcad you use. I do know in version 21 which is the most up to date I have you can get a run time estimate. After you create the g-code in the cam window you select the edit drop down menu on the cam side and choose select all. This should highlight all your g-code. You then go under the edit drop down and pick run time estimate. It will ask for machines rapid feed rate. After typing in your maximum rapid speed hit ok and it will calculate your run time. Good luck.
    Judleroy
    Feb 2007
    Smile
    If you are using Mach 3 controller, it has a simulate run with a time estimation.
    Nov 2010
    new zealand
    Quote Originally Posted by judleroy View Post
    Judleroy
    thats a good idea I am using V24 but have V21 somewhere at home so I wonder if could past the code into it?
    Nov 2010
    new zealand
    Quote Originally Posted by Claude Boudreau View Post
    Another good idea to think about I am not using a Mach 3 but could look at it as an option just to check machining time on the PC
    Most of our controllers at work don't give simulation times except 1 but thats on a lathe
    Dec 2006
    You should be able to open the g-code file in v-21with no problem. You may need to change the file mask under the file menu setup option on v21 depending on what the extension is in version 24.
    Judleroy
    Registered BobWarfield's Avatar
    May 2005
    G-Wizard Editor will estimate machining times and is free during the Beta test.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Oct 2010
    sorry, but where in predator could I find the estimated machining time ?
    Regards
    Kel
    Registered Machineit's Avatar
    Mar 2010
    Quote Originally Posted by nivlek View Post
    Regards
    Kel
    If you run your part through the predator simulator, there will be a small box on the bottom right side that will display the time it will take to machine the part.
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    Sep 2011
    You cant open up the file with toolpath included. If you were to import it in bobcad v21 you have to save as a dxf which is just the simple geometry program and then reprogram in the toolpaths
    Nov 2010
    new zealand
    I did get it to work in V21 by posting the file then opening up in preditor then copying the text and pasting into V21 CAM side.
    Then I simply did as judleroy said
    Works a treat.
    1. Some times there are good days and sometime bad.
      By Arich0908 in forum Benchtop Machines
      Last Post: 04-22-2010, 05:24 PM
    2. Need Help!- Cycle times
      By har78233 in forum BobCad-Cam
      Last Post: 03-10-2010, 08:50 PM
    3. Whacky Cycle Times
      By Technical Ted in forum Mastercam
      Last Post: 03-08-2009, 09:35 PM
    4. increasing cycle times
      By thetrillionaire in forum Haas Mills
      Last Post: 04-09-2008, 12:03 PM
    5. Hard Times ?
      By Switcher in forum CNCzone Club House
      Last Post: 02-26-2007, 11:09 AM
