Results 1 to 2 of 2
Thread: 4th axis help
    May 2006
    4th axis help
    i just started using v24 for 4th axis engraving. I got the setup no problem but it put the text upside down. i will post a pic and the file if anyone can help.
    Thanks Dave
    Attached Files Attached Files
    May 2006
    fixed
    just had to switch dir on 4th axis.
  1. Problem- a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2011, 10:45 PM
  2. 4-axis mill post and a-axis datum setting
    By inflateable in forum EdgeCam
    Last Post: 02-09-2011, 03:35 AM
  3. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum General CAM Discussion
    Last Post: 10-10-2008, 08:15 PM
  4. One axis (z-axis?) computer controlled testing device
    By TsThorsell in forum Stepper Motors and Drives
    Last Post: 02-07-2008, 01:38 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 03:58 PM
