If you just launch the installer again, there should be an option to "repair". This would be re-installing the app over itself..(Launch the installer with "run as admin") If you already had a license, it should still be there an untouched.... If you had many custom things setup, like tool databases full of self defined tools, you may want to just wait and get them (BC) on the phone so you dont loose your info...
How did the error come about after you already had it installed?
LinkBack URL
About LinkBacks
