Results 1 to 4 of 4
Thread: arcs to lines
    Mar 2008
    arcs to lines
    I need to machine an ellipse .758" x .365" using a .125 e/mill on a milltronics cent 6. I can create the ellipse in bobcad 19 but I get crazy arcs when using cutter comp on the machine. i think it would work fine if I could change all arcs to tiny lines - like vectorizing text.
    My plan is to load the dxf of the ellipse in the control using the cad feature on the conversational side and use mill start etc. Any help is appreciated. Russ
    Feb 2007
    Wink crop circles ?
    Quote Originally Posted by rmason View Post
    Not sure if this is your problem but if it is, a search on crop circles should bring some solutions.
    Mar 2008
    Thanks for that -at first I thought you were just being sarcastic. But that did get my program in lines only. unfortunately it still isn't smooth. I fooled with accuracy in the interpolate dialog box both larger and smaller (.05-.0005) didn't help. I think it may be in the post processor? not sure how to fool with that. any ideas? Thanks Russ
    Feb 2007
    Wink
    If you are using Mach 3 controller, there is a ( crop circles arc fix ) on that post
    BobCAD - leaving tabs in a cutout part
    Might want to read this first:
    http://bobcadsupport.com/techfaq/ind...=56&artlang=en
  1. Need Help!- Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 11:55 AM
  2. Lines & Arcs Not Showing Up
    By XxLT250RxX in forum Mastercam
    Last Post: 12-04-2009, 01:30 PM
  3. Converting lines to arcs?
    By Fleck in forum Rhino 3D
    Last Post: 03-14-2009, 01:47 PM
  4. Tangent lines joining two arcs
    By yongchiprsnapr in forum Mastercam
    Last Post: 11-30-2008, 05:39 PM
  5. points to lines/arcs
    By vmax549 in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 10-14-2008, 09:05 AM
