Results 1 to 11 of 11
Thread: Drawing 3D foam wing cores for RC airplanes V23
    Apr 2011
    Hello,
    I'm trying to draw a foam wing panel for an RC airplane. So far I have extruded a 2d shape. But I still need to:
    1. Taper the end, it's 10" at the root, 7" at the tip.
    2. Sweep the wing back - the tip is 5.5 inches back from the root.
    3. Add spar holes - remove cylinders from the middle of the wing.
    Here are finished ones I cut by hand: Tuffwing-Easy to Fly, Hard to Break RC Flying Wing EPP Foam.
    I will be cutting them on a 4 axis wire foam cutter. I have the Wire EDM.
    Tips? Thanks!
    Gold Member lovebugjunkie's Avatar
    Apr 2005
    Not sure you are looking for "Tips" outside of BobCad since you posted this in the BobCad section but you might want to consider other software that is dedicated for the job you are doing.
    Profili for doing wings and DevFus for making fuselages makes quick work of both.
    DevCad
    Profili 2.0 - wing airfoils managing, drawing and analysis software
    Tjzoide is also something you might want to look at for cutting foam wings and fuselages.
    http://www.tjzoide.com/
    Apr 2011
    Thanks luvbug, Yeah, I have Profili, and it's easy to make a panel, but it doesn't give me the control I want to cut multiple panels at once. I'm really hoping to get good enough at BobCAD to make other foam items as well.
    Quote Originally Posted by lovebugjunkie View Post
    DevCad
    TJZOIDE | 4 axis hotwire foam cutting CAD/CAM software
    May 2008
    never do it with bc
    someone better than me will have to explain how to
    Attached Thumbnails Attached Thumbnails Drawing 3D foam wing cores for RC airplanes V23-wing.jpg
    Apr 2011
    Awesome. How'd you do that?
    Quote Originally Posted by dwood View Post
    never do it with bc
    May 2008
    you were on the right track
    i just made up a end profile with spline
    translated y - 12 +x 6 to where end of wing would be
    made a copy positioned at 0 for center of wing (assuming end and center are same)
    so you have the center profile and end profile (offset)
    do a cross section should give the shell of wing
    put the end wire on a seperate layer out of the way
    extract edges single each end of the wing
    then planar surface
    stitch together all should have a solid
    mirror this with copy for other half of wing
    boolean add should have 1 solid
    not knowing the size of where the motor goes i made up some cubes
    and boolean sub till i got the look of the opening
    if you have that profile of that cut out you could position it and extrude curve
    then subtract that away
    this should be confusing enough
    May 2008
    a little visual
    stitch together after 3
    Attached Thumbnails Attached Thumbnails Drawing 3D foam wing cores for RC airplanes V23-wing_1.jpg   Drawing 3D foam wing cores for RC airplanes V23-wing2.jpg   Drawing 3D foam wing cores for RC airplanes V23-wing_3.jpg
    Apr 2011
    Any chance you'd send me your contact info?
    Thanks,
    brian.christal@gmail.com
    a little visual
    May 2006
    Interesting software Profili,
    If you need any cheap advice I've done wings for real aircraft,
    On basic CAD software, no need for single purpose software.
    NACA curve formulas, etc.
    Molds for all types.
    Been doing this too long
    May 2006
    May 2008
    bchristal
    try my private messages see if it works
    1. Routing full fuse airplanes out of foam
      By planekrazie in forum Parts for Radio Control Models
      Last Post: 09-27-2009, 06:57 AM
    2. CNC Foam cutter for RC plan wing
      By jc de campo in forum CNC Wire Foam Cutter Machines
      Last Post: 12-08-2008, 07:21 AM
    3. CNC foam wing cutters in the classroom
      By charper in forum Teachers Hang out
      Last Post: 11-06-2006, 02:59 AM
    4. Flat Foam Airplanes
      By tauscnc in forum Hobby Discussion
      Last Post: 10-01-2006, 11:17 PM
    5. RFQ - Need a prototype foam wing core cut
      By Quicker in forum Employment Opportunity
      Last Post: 08-01-2006, 04:26 PM
