Results 1 to 5 of 5
Thread: Problem With Solid Fillet
    Mar 2011
    canada
    I've drawn a solid 3-D model without stitching surfaces or stitching solids. I can't seem to fillet some of the edges. Any suggestions on what to try?
    Feb 2009
    Well, try stitching it... I think it has to be a solid to do a solid fillet. You need to form a solid out of the surfaces, then you should be able to fillet.
    Mar 2011
    canada
    I created the part from a solid and removed sections of it to create the part . my thinking was that it would eliminate any imperfections stiching surfaces or joining solids together. The customer is anxious and I am at a standstill ! I just get failed in solid fillit error. It seems it is when a section tapers into the part because it did work in some places. Sorry about the delay, I was away.
    Feb 2009
    If this is in v23, post the file or PM me and I can help. If it is in another version, good luck (I only have v23).
    Mar 2011
    canada
    It is version 23. I will try to do that right away. Thanks
    1. Problem- Fillet text in solid in V24?
      By nelZ in forum BobCad-Cam
      Last Post: 02-22-2011, 02:37 PM
    2. Problem with fillet finishing in RhinoCam2
      By CNC Viking in forum Visual Mill
      Last Post: 02-26-2010, 03:41 AM
    3. Need Help!- 3D Fillet problem
      By Powder_Keg in forum FeatureCAM CAD/CAM
      Last Post: 01-02-2009, 07:45 AM
    4. Need Help!- fillet in a solid v22 ???
      By hall6ppc in forum BobCad-Cam
      Last Post: 12-20-2008, 03:16 PM
    5. Problem with variable radius fillet
      By gibsonc in forum Solidworks
      Last Post: 05-15-2006, 12:13 PM
